Proforged Greasable LCA Shaft and Bushing Kit
Big Joe
6:41 AM
California
Howdy all. Anyone try this kit? It’s for my 70 Charger. I ordered it last week and it arrived today. Part number 120-10005. It includes shaft, rubber bushing and outer sleeve. Does not include inner sleeve that presses on shaft. However the rubber bushing has grooves in it for the grease to lube the shaft. I’m going to try it out.
B80A2B55-B08B-4074-BCC9-64D1EE53BE9D.jpeg B7153AC4-F087-4C18-A07F-8E7A0F1215DD.jpeg
At first I thought it was rubber but after second look it’s poly. I installed drivers side last night and it went good
Sorry to resurrect an old thread, but I got a set of these yesterday. How do you keep the shaft from rotating when you tighten the nut?
If I remember correctly, I used an impact to tighten up and then torqued the nut. Or you could hold the shaft with pliers or channel locks and then tighten the nut. Hope this helps
Thanks! I appreciate the help!
