- 7:39 AM
- Dec 4, 2009
- Pasadena, Texas
Wondering if using the Prestone Super Flush is OK to use in my 97 diesel pickup or is there something better or....? Next will be the Dakotas.
I like this stuff. It flushed out my old cast iron block and removed all traces of rust in my cooling system. Did it before I replaced radiator..., I was suprised how well it worked.Wondering if using the Prestone Super Flush is OK to use in my 97 diesel pickup or is there something better or....? Next will be the Dakotas.
Does it have lube in it for the water pump? Did a flush years ago and after driving around for several days, the pump started leaking.^ What Evan said. I drained the coolant, flushed with distilled, then refilled with Thermocure and distilled and ran for 3 days. OMG it cleaned the rust out of the jacket. It will take a good flushing after that, remove the block plugs each time or do with a hose. It comes out dark green/black and I flush every other year.
Run the G-05 coolant with alum. radiator.
Well, with the old junk I have, don't think that'll be a problem lolnewer trucks and cars have rubber seals for heater core and rad be careful that the cleaner doesn't eat the rubber and make a leak .
my 1998 dodge 3500 had a heater core with rubber sealed tanks .Does it have lube in it for the water pump? Did a flush years ago and after driving around for several days, the pump started leaking.
Well....my 97 has plastic tanks on the radiator so probably rubber seals on that too?? When someone says 'newer' cars and trucks, I don't think about something that's 23 years old as being newer lolmy 1998 dodge 3500 had a heater core with rubber sealed tanks .
IM just guessing but i think this method is more directed for the alliuium blocks,n on a cast block you mite have to increase the percentage to be higher n run it longer
