- 10:00 PM
- May 14, 2011
- On the Ridge, TN
I would but not running any right now, so....Back off ur vac.advance a little?
(When I hook it up, things get mighty jittery at cruise)
Thanks!
Man, I hope not. Engine was supposedly less than 1k miles from rebuilt when I got it,Some really good suggestions here, however I've run into that issue before and found that my timing chain was worn causing the timing to jump around a bit when it wasn't under load, went away when you squeezed down on the loud peddle. Sounds like a Saturday afternoon and a twelve pack kinda job... Good luck![]()
Great ideas surrounding any slop in the distributor/oil pump drive gear and/or slot....
Tell ya what, it doesn't take long to check out, at least rudimentary speaking, so I'm
headed out to the garage to yank the distributor and see what's what there.
Back with a report shortly.
Here ya go:Can you confirm the carb # for us
Before I go off , no pun intended , on the off idle to lean mixture on the Edelbrock AFB 1407/1411 750 Carbs that I have worked on in the past
AVS is a completely different model
Got a solid "house wiring" copper wire going from the back of the block to the bottom ECUMaybe getting a weak signal to the ECU at low RPM? Check reluctor to pickup gap, and run a ground strap from the ECU to the block.
Great job on the vid..Anyone? Ferris?
Sheesh, made the video for nuthin'....
Great job on the vid..![]()
Thanks for replying (and watching)!Well...the rotor is supposed to have the movement you show, that's the advance mechanism. Reach in with some needlenose pliers or whatever, pull the driveshaft up off of the cam gear, just enough to get the two gears clear of each other, then try to rock the shaft side to side to check for any wobble or looseness. Then pull it out and see how the tip of the distributor shaft engages it. Good time to see if the distributor shaft itself wobbles at all within the housing.
Thanks, but she ain't all that clean.Ed, motor is toooo clean, that's the problem! Remember to always check,recheck, grounds is what I say. Otherwise looks normal.
I brought that up post #25I am starting to lean towards blaming that "reman" carburetor, to be honest.
