I guess i did not read all the posts to see all that were suggested.
I was refering the the cams I have actually used.
My original 383 that I built in the late 1980's is close in specs and application, and ran the Crower 271 cam, but with headers.
It is a decent cam, but I felt like it was just a bit big for "street", and didn't pull on the top end like a big cam either.
Originally I had the Weiand Stealth dual plane intake, which was OK for "street", but seemed to limit the higher RPM power.
Back then there was no Performer RPM type intake which would have been a better match to the combination.
I then used the Weiand excellerator single plane. The engine seemed to like it from 2,500-6,000 RPM, but with my stock converter a bit slow off the line.
You have to remember that at my altitude, I am down about 20% power than if at sea-level, so for street use I tend to like milider cams.
I mentioned the Hughes Engines SEH1620 cam because I used one in a mild 360 with about 9.5:1 compression, and stock hi-stall converter, and really liked the results.
That Cam for the B-Block is SEH1620BL-12 It is 216/220@ 0.050", 0.495"/0.503" lift @ 1.5:1 rocker ratio. 112 LSA with 108 ICL.
In my 360, I ran the 1.6:1 rockers so got a bit more lift out of it, and maybe a tad more duration at the valve.
In the other thread with Nicks Garage 383 build, it shows the power that can be made with a large cam, but it is totally different setup than what the poster mentioned. That engine is single plane, headers, and higher RPM power.
I also did not mean to scare people away from the stock rocker arms system. It is good, and I did not have any problems with the crower 271 cam using stock rocker arms in my 383. You would just need to assess the condition of the originals. Mopar Performance used to sell replacements stamped out of thicker metal too. I don't know how good the replacements are from TRW?
The issue I did have with the 383 was accidently down shifting from Drive, past second and into first gear, over-reving the engine and bouncing the intake valves off the Sealed Power flat Tops that have no valve reliefs.
