View attachment 972956 View attachment 972957
Update. Since my last post I’ve:
Added overflow tank.
Added EMP thermostat.
Added flowkooler pump.
Added lower Radiator hose internal spring.
Added 14 1” holes with flappers to shroud.
Tried water wetter with distilled water.
Used foam to seal radiator to rad support.
And nothing. Maybe 2 degree drop on highway. Idle to 25 mph- 195 degrees
Over that on hwy at 70mph- 208. Only 84 degrees outside.
Possible causes?:
-My (2) 1320 cfm fans too small (12” pullers with 95amp alternator). Temp does come down from 210 to 195 but only when at idle so the fans are working better than high speed air flow.
- my 727 trans has a 2000 stall converter with 3:55 gears. Engine rpm is 3200 at 70 mph. Should I have a trans cooler?
-air fuel ratio is 13 at cruise so not lean.
-timing is 18-34 so not too advanced.
-using ported vacuum advance. Timing is 44 degrees in park at 3000 rpm when hooked up.
Any suggestions???
Yes added one.I did not go back and read the entire post or search but have you tried the internal spring in the lower radiator hose?
I have now. It’s a good one. Thanks!
My 440 doesn’t have a bypass hose?more trivia
the 361-413 "industrial" engines used a water pump housing an Robertshaw thermostat that closed the bypass when t stat opened
many latemotors do this
for a good reason
soooo
put a manual heater valve in your bypass hose and close it when you start getting hot
works
incidentally putting a standard B/RB t-stat in a motorhome will overheat
the truck t-stat will not work in the stock b/rb housing
someone who makes housings could make one with a bypass ckosing (the second disc)
t-stat
Thanks for this article! My complaints are very similar. I’m putting the stock iron housing back on tonight along with the stock pump. Hope this works! SonnyAfter reading thorough this whole thread: http://www.dodgecharger.com/forum/index.php/topic,60599.0.html
I'm using the stock cast iron water pump housing and this A1-Cardone water pump P/N #58-173. Can be had for $37.79 at RockAuto
Notice how the impeller is pretty close to factory and...
MADE IN USA... USA... USA... USA.. USA...
Interesting...When I put a 180 degree Robert Shaw stat in my 440, it made it very clear to me to get it the hell outta there. Didn't like it. I put a robert shaw 160 in it. My 440 is VERY happy now.
Those are not high flow. They all have the same 1.125" opening. The Robertshaw or EMP/Stewart are 1 7/16". The difference in flow is significant.
Darn phone, can you post a link to that thermostat I need a higher flow here in Vegas thank youThose are not high flow. They all have the same 1.125" opening. The Robertshaw or EMP/Stewart are 1 7/16". The difference in flow is significant.
Back at it today. So frustrating. 90 outside. Added an in series trans cooler. Still 210 on highway. Swapped my primary jets from 62s (13.2 afr) to 65s thinking I’m lean at cruise and since my plugs were white (cars faster but not cooler). Once it gets to 210 it just can’t get back down. It starts at 195 on highway but increases 2 degrees per mile. Under 50 mph it’s 180 all day long. Got home and trans cooler is warm to touch but not hot like radiator. I guess the new 12x12 trans cooler is blocking some airflow??? I guess I’ll completely bypass the radiator tonight as others have suggested and see if temp comes down. If not then what? My radiator is a 1 year old champion 3 row 26”. That’s all I have left to replace!Update. I think I made progress?
Previously at 84 degrees outside:
on hwy at 70mph- 208 degrees
today 90 degrees outside:
Idle to 25 mph 182!
Highway 196!
However, I got off the highway, sat at a light, put the car in neutral thinking the pump would run faster but the temp soared to 212. Took 2 miles at 45 to get Back down to 195, then in my driveway back down to 190.
Seems to cool down faster in gear vs in neutral when stopped. Normal?
here’s what I did:
1. Replaced the 440 source water pump housing with the original RV housing.
2. Put the Milodon 180 thermostat back in.
3. Installed the Napa stock water pump.
Definitely improvements noticed especially with hotter conditions outside.
With a 3 speed 727 trans running with 3:55 gears, I am going to add a trans cooler. Should I run separate or in series with radiator? Instructions say in series is best.
Thanks for all your input!!!
