- 9:44 AM
- May 14, 2011
- On the Ridge, TN
took it to a mechanic who has built race motors and he said i should be using oil with high zinc content like royal purple,and at least 10/40 or even 20/50 since i only drive in the summer.appreciate all your help
IF it's a flat tappet type cam, you should not be running synthetic in it to begin with.
Most synthetic oils are made for modern cars that don't have flat tappet cams (it's an emissions thing, for starters).
If you have a conventional cam like these cars came with, the mechanic is absolutely correct - make sure the oil has all the zinc (ZDDP) and phosphorus it should have for flat tappet cams or you'll surely wipe a lobe or two before long.
