Bad B-rad
So they are liars it was $5 bucks a month, but I paid and watched it.
I will save everyone the 5 bucks, as tested the stock motorhome 440 with 7.2 to one CR, and headers made 319HP @ 4300rpm and 452TQ @3200.
They advanced timing to 41 degrees and got 327.7 HP @4400RPM, and 457.8 TQ @3100rpm.
Next Dulcich added a comps cam 'THUMPER" grind 227/241@fifty thou and 486/473 lift , installed at 101 deg.
Added a summit timing chain with 9 key way combos, and an Edelbrock performer rpm intake manifold, with a Holley brawler 850 double pumper.
Steve Dulcich said he picked that cam, and that installed centerline (101 degrees) to help the low compression.
On the dyno it made 381.7HP@4900rpm, and 476LBS TQ@3500rpm, so added 54HP and 18ftlbs tq.
They commented on how the factory cam was DEAD by 5,000rpm, and that factory heads were the reason this engine didnt see larger results from the parts swap.
I wonder how a set of stealth 440 source heads would help.
I personally LOVE the performer RPM intake for the street, but I prefer vacuum 2nds, and might go with an 800CFM AVS, but I dont have an engine dyno, and/or a tv show so, they must know.
I was VERY surprised by the stock HP numbers with just headers, on this engine, I noticed they tested with no belt driven items(wp/PS/Alt)
It is almost hard to believe that stock Chrysler said 235HP, and with timing and headers, and no accessories, they got 319HP using stock thermoquad!!
I guess a fan COULD eat 15-20HP, plus the WP.....
