Ben Mowery
- 10:07 AM
- Aug 18, 2018
- Indianapolis, Indiana
So I am having some issues with setting up the ring and pinion in my center section. The background is my GTX was equipped with a 3.23 open diff. I wanted to convert to sure-grip. I purchased a Yukon sure-grip. This unit uses early style bearings from what I have read. So I removed gear from old carrier and installed with new bolts on sure-grip unit and bearings. I installed a new race in both ends of case and a new front pinion bearing along with a crush sleeve eliminator. I chose to reuse the rear pinion bearing as it didn't look bad. I installed pinion and set preload. I had a pretty steady 15 in. lbs. From there installed the carrier and set backlash. Had about .007" backlash at the tightest spot. So I am thinking I am home free since I am reusing rear bearing and shim that was on the pinion. I go to check the pattern and it appears as if the pinion needs shimmed up more. So my question is if this is possible? If so what may have caused it? Is there a chance the race for the rear bearing in in too far? I did a double check with a T&D set-up too with a new bearing setting in the race I measured that I need 0.031" shim. The gear is a +1 so a 0.030" shim. Out of curiosity today I pressed the bearing off and it has a 0.030" under it. At any rate I am at a loss and was hoping maybe someone might have some insight.
