70chall440
- 12:31 AM
- Feb 11, 2018
- Yelm, Washington
Appreciate the advice, its exactly what I intend to do and have done in the past. Funny you should mention the electrical system, I build one for my 73 Cuda and am in the process of installing a brand new aftermarket harness in a 69 Plymouth wagon as we speak. I have not used Painless, but I have used several others that worked very well. I know some really like painless but for the cost I think there are just as good systems out there for a lot less.
When I do these cars I use a lot of the original connector bodies and put in new connectors (packard 56) and is some cases I use Weatherpack or something similar if needed. I know what you mean about installing multiple times, I had the engine in and out of the Cuda probably 4-6 times mocking everything up and this car will be no different. If i were just doing a rebuild I probably would not be too concerned about it but if I do go G3 Hemi I want to make sure it is where I want it and it can live without issue.
