Meep-Meep
дворянин
Hey there, it's been about 35 years since I been into one of these (mostly 4 speeds lately) and I'd like some input on what may be going on here. Pretty sure I have all the parts installed and correctly but I have a lot of input shaft end play. Like a shitload. Tail shaft is in and tight with gasket and the rear ball bearing is seated in the snap ring. The gear train has the desired clearance after adding about .030" shim behind one of the thrust washers.
With the tranny on it's side I can push the input all the way in until it stops then pull it out until it stops but the movement is damn near 1/4" as if I left out one of the fiber washers, which I did not. I did get a 4 clutch drum and low gear set from A&A and all that seemed to be fine but I did not compare the difference to the old stuff. Also keep in mind this is an original 69 tranny that looks like it's never been apart and was working fine. Yeah, yeah, if it works don't fix it.... But it's good I pulled it apart because the high gear clutch pack was badly worn and the piston seals have taken a set. Looking at FSM diagrams I can't imagine I left something out and want to know how I can end up with damn near 1/4" of end play when the FSM says up to about .080".
Here are pics of the input shaft all the way in and all the way out. Note in the "all the way in" pic you can't see the rear clutch assembly but in the "all the way out" pic you can see the edge of it peeking through the slots in the drive shell. I'd love to get my leaning tower of power Dart back up and running but it's fighting me every step of the way. Might be a sign that it needs a hemi.
