Why it's a good idea to consider wiring harness replacement
signalsparks
11:42 PM
Concord, CA
Over the last year I've had with the car, my ammeter would regularly dance like a pop star on angel dust and other electrical gremlins. I felt it was time to replace the wiring harnesses. I think I found one of the problems...
Yep that was the first thing I did when I bought my Bee,50 year old wiring not good. Glad you didnt have a fire.
I replaced all the harnesses in mine when I bought it 9 years ago,M&H from year one,the main was a little expensive but exact match worth every penny.
Excellent idea! That's why I rewired my whole car!
this is the pile after pulling it out. There were several spots like yours!
One of the first things I do is throw the whole harness in the trash and buy a universal harness, I don't want that factory spaghetti garbage lol.
Inspected closely and put my dash harness back in to save $400.. replaced the over heated and timeX'd engine harness, but did take the time to replace the main bulkhead block and all it's connectors. I have more faith in the original OE copper and wire gauge than a reproduction unfortunately...
Are all the wiring harnesses Year One sells come from M&H
Electrical, must be checked, just like brakes, suspension, cooling system... to stop blaming who is not guilty LOL
Inspected closely and put my dash harness back in to save $400.. replaced the over heated and timeX'd engine harness, but did take the time to replace the main bulkhead block and all it's connectors. I have more faith in the original OE copper and wire gauge than a reproduction unfortunately... View attachment 996332
I'm with you... to a point. I checked the gauge on my new M & H harness. It's legit. I also replaced the taillight/fuel gauge harness running under the driver's side sill plate yesterday. As I was coiling up the old one, "crack-crack" the brittle insulation just snapped. Sure, the wires could be 'fine' for another 10-15 years if you just leave it alone. Trouble is, in cars things shake, get hot, get cold, get humid, and get dry. I changed a burnt-out tail light bulb a few weeks ago and the jacket on one of the leads snapped. I had to wire-nut in a new bulb holder.
I replaced the engine harness and headlight harness so far in my 1967 Coronet. Both harnesses had numerous splices and other wires added in. In the end I determined that the harnesses had been replaced at some point with a harness from a different car. I still need to work on the interior harnesses.
I have a friend with a 1976 Plymouth Arrow (Mitsubishi captive import) that he'd rigged for autocross. He had an engine fire, and the insurance company was going to total the car until he produced a stack of receipts for the modifications he'd done. He heard nothing until the body shop called and said "come pick up your car!" They'd bought another wrecked car (unknown make/model) and cannibalized it for the wiring harness. It was never right. Too bad he is so electro-phobic he won't touch it. It has been sitting in his garage since 1987.
