Yeahrightgreer
Hey lads, been having an issue with my fuel delivery and thought maybe someone can chime in.
Been having problems with this old Q-Jet for years and finally decided to rebuild it on my ‘88 Dodge P/U with a 360. After soaking/cleaning/rebuilding it runs much better however it has started running extremely lean
When cold and the choke partial it runs great, however once the choke reaches wide open it runs extremely lean and starts to run intermittently. Adjusting the choke and mixture screws make no noticeable difference. Once the engine reaches operating temp, the lean situation intensifies, to the point that once hot, it won’t stall out but if shut off, it won’t restart.
It’s not vapor lock. It will turn over, spark, and start in the “Ignition Start” position and if throttle is held then die when key is released. Mimicking almost exactly as if the “Ignition Run” fuse was blown or a fusible link burnt etc (that’s what I initially thought it was). Once the engine is, it starts again just like normal
The ECU has been replaced, ignition coil, fuel filter, spark plugs, wires, air filter, and all other regular tune up pieces. Never had a problem with vapor lock or fuel overheating
Does it just sound like something as silly as a bad carb to manifold/air horn gasket? That’s what makes sense to me.
Sorry for such novice questions.
