Exhaust Manifold dripping Anti Freeze
Duck
4:41 PM
Manitowoc WI.
72 Dodge 440 leaking antifreeze. put a new gasket in.
The were bolts in all holes except last (by fire wall) was a stud
Did put Permatex on all bolts (threads)
manifold is flat
ANY HELP
manifold is flat
ANY HELP
Outer studs on both heads go through to the water jacket. It's a PITA but they'll need some pipe dope/sealant.
Double check where the antifreeze is coming from. Looking up from underneath works better. There's frost plugs behind the manifold also. Renting a pressure guage from your local parts store can speed things up if you pressurize the system.
all of your exhaust manifold bolts go into coolant on a big block. Sometimes permatex will not do the trick on a wet hole.
You need to drain down your coolant below the heads , blow them out with some air and use a heat rated PTFE pipe sealer / pipe dope.
If its steam rated its good. put it together and let it sit over night before refilling.
Others have different ways but this is what I do.
I have had good luck using loctite on the threads
ONLY the two outside exhaust studs go into the water jacket
More misinformation spreading
Misinformation ?
Better dbl check that one.
Looks like all exhaust studs are in water jackets on my 906 heads. Maybe other cast numbers differ?? I'm not sure.... i can post picks as I currently have them all out. 1968 440
So I ran out and took picks, the end studs you can clearly see back in the heads with a light. The insides ones appear to have iron behind them , but do not. If I take my air gun I can push air no problem threw, they have opening access on the tops of the holes for the most part. I tried to capture it in the photo but pretty difficult to see. Surry I tried. # 5 & 7 exh ports below
