Question: are the valve springs on on my Edelbrock E-Street #5090 heads to stiff for the stamped steel rockers? Edelbrock rates these springs at 280 pounds at .500", and I've been told factory springs, say from a 440 GTX from 1970, would be less than that, and that could have been a cause of failure. I'm still waiting for the parts to come in, which as I've said before, will be coming from Melling. I'd love to hear if people have some thoughts on the added spring pressure of these heads compared to what would have been used 50 years ago.
I have been running a crane spring with the same 280lb rate and 90 closed on mopar stamped rockers. my cam is only .470 xe comp. I have had it together for a couple summers now, no problems rocker , spring wise.
I probably could match that offer...
