Challenger340
- 7:39 PM
- Mar 4, 2014
- Moyie Lake, B.C. Canada
I'm getting anxious to get some new heads ordered, and Todd from Marsh Performance hasn't had a chance to get back to me. Have the problems with the Stealth heads been corrected? Do they still need to have the locks and retainers replaced and has the quality control improved so they really could be bolted on after a quick inspection at the machine shop? I'm going to take the old 516 heads over there today to see if the valve springs might have been replaced with the camshaft during the last rebuild. Would you reuse the camshaft and valve springs if they were good?
We still use 5-10 sets of Stealth Heads per year at our shop, mostly for our 'resto' underhood appearance type Engine builds, NOT aware of any problems with Stealth's other than they must be dis-assembled/Checked/ re-Lubed..... which we always upgrade to 10* Locks & Retainers while we are in there and you should as well !
We would never re-use a "used" Camshaft supplied to us with no known personal continuity as we are a Shop and Dyno ever Engine we Machine/Build before it leaves, far too much Customer liability for us..... that said. as long as YOU personally are confident you "indexed" the Lifters to their Lobes, and you can put them back on their same Lobes during re-assembly ? then that's your call
