Hey everybody
bobtile
9:58 PM
NJ
LOOK!
I'm actually working on a b-body too!
Some progress on the kid's Coronet.
Out with the 'lil guy and in with the 8.75.
The heart ❤ of the GTX which made a best pass of 11.20@ 121 is going into this car. No changes to the engine , trans or rear. Body, suspension, and knowledge are the only upgrades. Wheels, and tires are the same as well. Hoping to be on track in the spring.
What do you think she'll do?
I'm with @cdr an 11.50 maybe,
after running a couple of mid to hi-12 second passes 1st
it will still run 120-ish if it isn't wounded, he stays on it out the back
& if stuff goes well, if the kid can drive, as well as he takes photos :poke:
1st time out "maybe"
how much more does it weight than the GTX did ?
couple hundred pounds ? an extra tenth+ for every extra 100#'s
no glass hood or bumpers, or alum. bumper brackets ?
is it totally gutted or full interior ?
do you have any frame stiffing done ?
subframe connectors, roll bar etc.
good luck
good luck
The kid can drive.
The car will be gutted. It has a cage and will have subframe connectors.
Should be lighter than the GTX by a couple hundred pounds.
Motor will be fresh.
I'm thinking it'll go 10's.
The kid can drive.
:thumbsup:
I hope so :bananadance:
Well both are B-bodies and should weigh close to the same so I say 11.50's or better. I know I was surprised as how well my kid drove at the track right from his first pass so I know our kids can drive. Best of luck to you guys. Ron
11.10@ 123
In good cool spring air 2021
