Who uses Dielectric grease for their bulkhead terminals?
Kern Dog
Life is full of turns. Build your car to handle.
Granite Bay CA
I never have before. I have several Mopars here that don't have electrical problems even though they sit awhile between drives.
My project car has some electrical problems that I am working on including the replacement of the bulkhead plug and fuse box. As I start putting it back together, I am curious about using the grease to reduce the risk of corrosion. The humidity here is relatively low but the Wife and I are considering a move to a place that may be more humid. I thought I read somewhere that the corrosion gets worse with higher humidity.
If I do use the stuff, I'm guessing that each terminal only needs a small amount.
I think it's a good idea regardless if you live in a humid environment or not. It certainly won't hurt anything. 440'
I have started using it on most electrical connections. I used to put wheel bearing grease on battery terminals to try and prevent corrosion. But now, the dielectric grease is so much nicer and cleaner. And it really helps on trailer plugs and connectors too.
If it needs cleaning deoxit is the finest, I also use good old trusty WD-40 and definitely put some silicone grease in there...
It is good stuff!
Just bought some today and will be using it on the bulkhead repair I'm dealing with. Lots of corrosion when I took it apart.
Just a reminder:
Where should you not use dielectric grease?
Since dielectric grease is a silicone grease, it should not be used on silicone-based rubbers or plastics, as it will break them down over time. The grease does not conduct electricity, so it shouldn't be applied directly to the mating surfaces (pins and sockets) of an electrical connection.Feb 26, 2015
From: https://www.farmandfleet.com/blog/what-is-dielectric-grease/
Just a reminder:
Dielectric is not conductive.
Like some other topics where some swear by one SOP or the other, found that more have suggested di-electric grease to thwart corrosion. After replacing my BH I used it. Wasn't something I did years ago but a mechanic buddy was all over me to use the stuff.
Never used it. I use a little bit of Lucas red tacky grease and wipe it off....just a residue left...
