- 5:57 AM
- Apr 13, 2012
- Granite Bay CA
I never have before. I have several Mopars here that don't have electrical problems even though they sit awhile between drives.
My project car has some electrical problems that I am working on including the replacement of the bulkhead plug and fuse box. As I start putting it back together, I am curious about using the grease to reduce the risk of corrosion. The humidity here is relatively low but the Wife and I are considering a move to a place that may be more humid. I thought I read somewhere that the corrosion gets worse with higher humidity.
If I do use the stuff, I'm guessing that each terminal only needs a small amount.
