Can't read the dipstick ?
Cornpatch MO
1:44 AM
Southwest Iowa
I do have rather low vision, but others can't see it either. 904 auto transmission. The fluid is so near clear, I can't see easily where it is on the dipstick. I was thinking about sanding the metal a little and painting the end with a high heat flat black paint. That should give better contrast. But will it come off? Anyone else have an idea that has worked for them? ........................MO
I just look at how far up my stick is wet. Should this be in the blue forum?
Get it powder coated. :poke:
Yep, powder coating is a good idea. I think someone here on site specialises in that field. :thumbsup:
If you hold it towards the light at the right angle, you can see the shine of the fluid.
That is how I do it, but the dipstick is shiney enough, it is very hard to see. Also when the level is at the "twist" in the stick, that is hard to see too. Even people with good vision have trouble seeing it.. Thanks........................MO
Is this an old dipstick - original - or an aftermarket one....you didn't mention that in the OP.
Red fluid.. and you can't see it...??
That's right. It is new Valvolene fluid , but doesn't seem as dark red as it used to be a few years ago. You can put some on a clean paper towel and it is barely pink........................MO
