65 Satellite w/ 318 poly
Ron I still think there's something not right with your poly - maybe cam timing or perhaps the exhaust is too big. I haven't got headers, just the restrictive factory manifolds and that's probably costing me some mid range and top end performance but with 3.23 gears it rips off the line. I've smoked some pretty decent cars up to 60 or so. What camshaft is in yours?
Cam - 262 duration 450 lift...
Ron that is very similar to the camshaft in mine and it runs like a champ with a stock converter and 3.23 rear end. It will rev strongly to 5,800 and that's with stock exhaust manifolds. It is a little softer at the bottom end compared to the 258 cam I had in it previously, but not that noticeable.
I suggest you send Gary Pavlovich all the info you have on your engine and see if he can offer some insight. He's both very knowledgeable on these engines and also extremely helpful. The fact it won't run properly with the vacuum advance connected must tell some story to people who understand timing.
Interesting, Poly's are fun because of the challenge .I like what's different (That's why I don't have a Camaro or Mustang)
For the street it will be great.The Weiand single plane is a bit lazy on the bottom end. I really like the new CP manifold.
A friend did a stroked 390 Poly in a 64 Dodge wagon with 3.23 gear.It's a killer on the street and to me it will go toe to toe with a big block.AS I said "On the street".
Like many have said above is it the right engine ? or is a 440 better. As far as cost and availability the 440 stands tall.
Some guys love to be different,I'm a fan of the unwanted Red Headed Step child.Slants,Poly's,even the B 361 that I have future plans for.
I would say,Do what your wallet allows.Then go for it !
I would say,Do what your wallet allows.Then go for it !View attachment 1038739
Damn that's nice! Looks stock with a kick!!!!
Wait a minute - what kind of manifold are you running? My '66 doesn't have a separate valley pan like that one...
Wait a minute - what kind of manifold are you running? My '66 doesn't have a separate valley pan like that one...View attachment 1039075
I don't mean to answer for Darter6 but Chrysler Power has been producing these manifolds and aluminum valve covers for a few years now. I see on their website they are looking for a new foundry to produce them. https://cpwebstore.com/Poly
I could probably find them a aluminum foundry or two here in the midwest.
That looks great. I installed stock cast iron 4 bbl intakte on mine with 600 cfm carter in a 64 polara. I was scared of the height, so I did not bought it. Do you need a hood scoop to run it on your poly?
A poly stroker with 400hp and 400+ lbs ft should make for a fun street car. Talk to Gary Pavlovich once you have the verdict from the machine shop, and then cost out all the options. A 440 is obviously a good option, or a 408 small block crate engine. The stroked poly will be more effort to build and possibly more expensive, but you end up with something unique, that looks great when you pop the hood.
I love my 318 poly but I wish I'd gone the extra mile and stroked it.
I bought a motor home with a running 360 for 200 bucks!
Very interesting thread on the Poly engine. To cut to the chase, I always say that if you want more than 400-425 HP @ 5700RPM & 440-470TQ @ 3600RPM from the indigenous Poly in your Mopar then by all means go for the Big Block 440. The Torque is high & flat...about 400ft.lbs. at 2200rpm. You will be hard-pressed to get traction with a 390" (.030" overbore) Stroker Poly and the cost is reasonable & comparable to the LA build. Given, the intake/cam is more expensive but that appreciate cost increase must justify/satisy one's need for a unique and massive looking powerplant under your hood; 1.5" wider than a 440. The aforementioned HP/TQ is easily created & replicated each every time with many of the common LA parts 4" cast steel SCAT 340 Stroker crank (approx. $400), Eagle SIR LA rods (approx. $315)...SCAT is better IMHO, M72HV Oil Pump (...$85), all KING or Clevite rod/main/cam brgs, same .250" seamless pin dbl. roller timing set...the "rub" expense comes primarily with the intake selection but the best bang for the buck is to use the ancient but powerful factory dual quad intake...yes, the last factory dual quad build we did made 463TQ @ 3500rpm/468 peak TQ @ 4100rpm & 421HP @ 5500rpm...and these dual quads are plentiful and I have a friend selling one for a very reasonable $300. This 421HP/463TQ Poly Stroker engine has 9.5 compression/ported heads/284adv .510" lift (242@.050") flat-tappet Poly Cam, TTI Headers...the basics. However, the Poly has a superior chamber design (polyspherical) to the Wedge motor (I also run a 340 Dart) and has an excellent BMEP cf with the HEMI and the Poly ports have extreme velocity w/o stall; up to 1" lift. Yet a paltry 210cfm intake/160cfm exhaust flow @ .500" yields the aforementioned power; although for the sake of exaggeration, we have a CNC program and other "hand-porting" techniques to get us up to and over 600HP & 580TQ if needed/wanted; see Buck Hinkle 426 Poly Stroker motor article. Yes, the camshafts are more expensive but you can circumvent that by regrinding your old cam core...now you just undercut the price of the LA HP Cam...although new HP Poly Cams are available as well as Poly Roller Cams...I have several...and the Poly Roller Cam is created by using the LA Round Lobe Billet Core...therefore same cost as the LA Roller Cam. You can also achieve the 400+HP & TQ using the stock 1.84/1.56 Poly valves...just need the porting expertise. OK...you will need custom Poly pistons; very reasonable from Auto Tech for approx. $650 a set....
I ended up buying a running 360 out of a motor home for 200$. You think that dual quad carb set up is still for sale? Haha I was wondering if I can put the poly heads on that 360 and make something cool like that. From my understanding it’s still a small block but I’m not sure if it’ll bolt on the same. I’m going to buy a battery and belt for this motor so I can get it running right before I rip the motor out and put it in my beautiful 65. I’ve polished the chrome and kept the patina finish. I need to replace the seats and interior though.
