- 5:52 AM
- Apr 13, 2012
- Granite Bay CA
I may do that. I don't recall if I looked as close as I should have when installing the plastic tray. I used the same type of gasket in the 727 and even it weeped a slight amount.While you have your oil pan off for repair, see if the embossed sealing ribs are going across the indents in the pan rail causing it to not seal correctly. It seems those type of gaskets are made with flat machined surfaces in mind, not stamped sheet metal like the stock engine and auto trans pans.
Travis..
I am frustrated with dealing with leaks. It isn't so much a matter of what reaches the pavement as much as the mess it makes under the car. I bought valve cover gaskets too. I am going to start with them first. The #8 header tube had evidence of oil staining up near the port. I haven't checked the lower rear valve cover bolt on that side to see if it is tight enough. I am thinking of putting studs in the lower corners of both sides to make sure that the gaskets don't get moved on assembly.
