68 roadrunner floor support
68dirtybird
8:48 PM
Lexington tn
I'm needing some measurements for my floor support brackets mine was to bad to measure .thanks
What do you want measured?
Do you need distance from crossmember to each support or something else? My floor is currently removed so easy to measure if you tell me how you will align them.
RGAZ
RGAZ
Yea that will be fine from crossmember to each support thank you
Pictures are worth 1000 words. Note: the rocker has slight depressions where the mounts go, so it should be obvious.
Hope this helps.
RGAZ
