Loose shifter ring causing rattling noise
Leftee95
6:25 PM
Santa Cruz, CA
The only rattling noise my ‘66 Satellite makes is from the loose ring inside the shifter surrounding the engage button. I’d love to know how to disassemble this and add a gasket? Other suggestions to tighten it up and prevent it from rattling around in there?
0575E59D-DFC0-491E-9314-2BF4928204C2.jpeg 3305BB0A-18BC-448B-8A63-E5FDE009C3D0.jpeg
The button looks to be adjusted a little deep. Loosen the set screw and spin the knob until the ribbed part is more flush with the housing. Set screw should be at 6 o'clock.
Have the same problem, thought about using a 1/8" strip of clear tape around button. The part of button that inside outer housing.
You could down grade it to the updated plastic knob. I just keep my thumb on it.
