1977 440 HP horsepower rating
Sam69sat
1:48 AM
Earth
Does anyone know the horsepower ratings on a 1977 440 HP motor? I'm guessing it probably came out of a cop car. This motor any good or is it just a basic 440 engine and nothing special. This is what's stamped on it.
7T44 TE HP
I had a similar engine a long time ago, and from what I (vaguely) remember, the cop motors were built similar to the old 375 HP Magnums but the compression was lower for emissions. I read somewhere that a pedestrian 440 had 8 something compression, but a cop motor was in the 7's!
I tended to believe that claim because mine would run on any octane with no issues.
As for special cop parts, most of what made it 'special' would be replaced anyway with a full rebuild.
. The 75 was 260, 76 was 240,and the 77 was 195 HP. The 400 was only down to 190.
The 440 was down to the last year(78) they ran terible, overheated, and smelled like rotten eggs all the time. I know because i had to work on them, and had friends that owned them.
Now today with a fresh 69 383 or 440 HP in a Cordoba would make a really nice package.
https://www.hamtramck-historical.co...ataBook/1977/77-Chrysler-engineering_0004.jpgNot sure if this is a hp...but in 77 a 440 had whopping lean burning 195 hp. Go to 1970hamtramck historical and look the library.
True, there are two 440 HP in 1977. one is lean burn, one is high altitude. one is 195, the other is 190.
Cool. I saw one come up for $750 but it's pretty far away from me. Sounds like i might be better off with any run of the mill 440 especially an earlier year.
Good blocks. They have a better casting. Dick Landy's go to block was a late 70's for the thicker journals and higher nickel content
72 and earlier 440s had the better nickel content, but their isn't that much difference. The later 440s have thicker motor mount ears and reinforcements in several places. 440 source is a good resource for the different years. The hp typically had windage tray, double roller chain, better springs w dampers and the magnum cam. 77 era 360 e58 Police motors have better valves and higher nickel block, but I have never seen where a 440 had those features..and I have never seen a 77 440hp to really know how it's equipped. .http://www.440source.com/blockinfo.htm
Thats where I sourced that. My memory just sucks, my bad on the nickel reference!
If it's a cop-spec or "Heavy Duty" 440, it would have had the following (as per Chrysler's marketing literature):
- Double Roller timing chain
- Moly filled compression rings
- Lubrite treated camshaft (with the same specs as the older high compression 440 magnums)
- Heavier duty rocker arms
- valve spring dampers
- windage trays
- high temp valve seals
- special connecting rods
- shotpeened Nodular iron crankshaft
There were other special features for the ancillary components, namely cooling systems and electrical, but the above apply to the engine itself. These were all added to enable the engine to run for much longer intervals under load, but most didn't contribute to more power.
That said, with the exception of the windage trays & roller chain, not sure if every heavy-duty engine had all of these. Many others have pointed out that could be how the assembly line built the engine that day. I'm also curious as to what the mean by "Special Connecting rods" as that would indicate the six-pack rods, but that would require an extra crank counterweight whereas the cast crank is already a pretty beefy piece so not much room left.
Check out this book for more details too:
Amazon product ASIN 0879389583
EDIT: And the E86 (U code) 440/4 barrel pursuit was also rated at 255HP and 355 lb/ft for 1977 and1978. Given the smog-laden late 70's, they were healthy mills. If you have one, be sure to hold onto it.
Interesting. I actually bought the 440 HP engine i talked about at the beginning of the post but haven't even looked into into it yet. All i know is that it turns. Another weird thing happened when i bought the engine. After picking it up near Eugene, Or i drove up to the Puget Sound area across from Seattle the same day to pick up some parts for my coronet. I got to to talking with the guy selling me the coronet parts and he said he had the exact same engine. About a year later i ended up buying that engine too so now i have two of them.
Going to need new pistons anyway, nothing wrong with it as a core.
If the later 440's are in good shape and standard bore...the oem 67-70 350hp 440 pistons are identical in regard to where the rings are on the piston. They are just taller. So if you want a cheap motor with better compression find a used set of pistons from the higher compression 440 era and they drop right in the 72-77 440. 71 was a odd piston year for the 440 but still a healthy compression upgrade. Of course boring and new pistons are nice...but nothing wrong w throwing something together and having fun while saving a buck.
