What did you do today....other than work on your car!?
Put some cat pee in.my Passat Diesel's DEF tank.
Checked out the offerings for a consignment auction tomorrow.
Got my hair cut.
That was my off-Friday in 30 words or less.
Pulled old dining room table out of shed! I put it in there a few years back because the puppy used the bottom as a chew toy why we were gone . It's the matching table to my side buffet and credenza all from 1920 have the org order forms !
Anyways it suffered some more damage then I remembered. I removed all bottom support areas and decided instead or replicating them I would upgrade them! They never had enough room for the chairs to slide under fully! (Wasn't designed for 2 in center area) so I made the bars straight across to give me more room as I need this table to seat 10 at least . I love the org chair s but being 100 years old I can't find more only have the org 6 and there hard to duplicate!
So I've been on the hunt for affordable chair's and hit damn I found $2000 worth of chair's for $150
Chairs are mint and look great will blend well into my set !
I'll be giving table a new coat of stain tomorrow and adding some trim to bottom to fancy it up !!
Finished cutting, splitting ALL my firewood for next year, Stacked and filled my woodshed!! Great feeling knowing I got all that "free" heat finished & ready to go!!!
Pushed out 1000' tree row this afternoon...sad day for tree huggers :poke:
80,000 lb dozer can do some serious damage..
Took a big bag engine fasteners to a good friends to get them black phosphate coated and some zinc plating lined up fo some other stuff... Cleaning bolts suck, thank God for a tumbler ! Chased a bunch of threads the look like brand new ! Can’t wait to see them coated!
This morning I was helping my brother move to the next field of corn. We run older equipment, always something to fix. :cursin: Need to get done so we can get back to our car projects.
Been cleaning up around the shop and getting rid of stuff I know I'm never going to use. It's mostly old parts that can be reconditioned but seems no one wants it unless I give it away for free or little of nothing...so that's what I'm doing.
Curious yellow71, I miss field and farm work... it’s hard work but very rewarding unless the Mother Nature beats you at the game.
Adding winch and box onto my tilt car trailer. Made the bracket for winch along with a base for my box welded up and rattle canned it. Will Finish adding the box today and complete the wiring. Use some Anderson connectors and add battery inside the
44ECCC01-83DB-44B5-AFDB-94B90DF79EAC.jpeg 4750AFFE-8125-4037-8DEF-4E40ABCBB7E2.jpeg
There is a lot 2 like, but some things aren't much fun, but it's got 2 be done.
I've always loved iron, livestock never was my thing...with the exception of our dogs.:) and they are say'n play time!
After all the wood was moved and the debris raked up.. My son decided before planting some grass we should remove the rocks (ice bergs) that were sticking up a few inches... Hammer drilled some holes, used some masonry bits and broke them apart. 4 hours later we got them all out and was able to fill most of the holes back in...
View attachment 1105806 View attachment 1105807
