dvw
The 64 was a local car here. Solid 8.880 car
What did that kid say??Who are all the old guys standing next to the hot babe (Leah).![]()
Hey Mike GainesUse Hughes Cryo Rockers
Well, there is always the Triplex!Waiting for my tri-motor Cyber Truck![]()
92 Octane 14psi short pull to 5500 trying to work out the tune. 900whp. Should go 8’s on pump gas.
Yeah. But no gearbox? Needing to push start? Hardly street. And WAY too much weight. But does go to show? "Crazy" is not a generation thing?Well, there is always the Triplex!
(Three engine land speed record car. 5000+ cu in. Scared the crap out of the regular driver, killed his replacment, but was fastest car on earth, for a while)
I did not dyno the engine prior to going in the car. We’ve yet to put any real boost or rpm to it so I’m expecting a significant gain once we get it on race fuel.Hemirunner, did you by any chance dyno the motor before you put it in the car? (I know you plumbed the turbos in the car to make sure of the fit).
Im curious how much power is absorbed by the drivetrain with an engine this powerful.
Thanks. These turbos are quite small for the cubic inches. It’ll never be efficient but it should still make great power. Can’t wait to have it out this year.
I assume that the layout of the twin turbos is efficient and highly functional, but I KNOW FOR A FACT that the appearance of their placement is, well...
I guess what I mean is your turbos plumbing is laid out so as to not be "loss-y" by its design? Small turbos when you have 2 of them, so beautifully symmetrical, and I assume meeting your anticipated power goals? are a GREAT choice, spooling up faster than a single larger turbo, and providing good power at the push of the loud pedal.These turbos are quite small for the cubic inches. It’ll never be efficient but it should still make great power.
The main goal of the piping was to get the air from the turbos to the intake without butchering the car and allow me to run a stock style radiator, mechanical pump and clutch fan and AC. I also wanted to retain the stock front bumper. I succeeded in hitting all the goals. I didn’t have room for an intercooler but the water meth will get it done.I guess what I mean is your turbos plumbing is laid out so as to not be "loss-y" by its design? Small turbos when you have 2 of them, so beautifully symmetrical, and I assume meeting your anticipated power goals? are a GREAT choice, spooling up faster than a single larger turbo, and providing good power at the push of the loud pedal.
Anyway, from the first time I saw "pix of the Twins" and your car overall, I have always been impressed and probably the only idea that had me think-for a moment-about "Well who says I must have a 6bbl?" LOL, but that passed and I'm back to displacement and my 6bbl as my "route to power" with an option for some nitrous...
Mechanical water pump I assume, NOT fuel pump?a stock style radiator, mechanical pump and clutch fan and AC.
Mechanical water pump as well. Oiling system is mechanical dry sump pump that bolts on like the factory pump. We modified it to accept a drive cable that also runs a mechanical fuel pump for quiet, high volume operation. I made the oil tank so that it would fit under the left front fender. Yes, that’s a CVF Wraptor. It really tucked the AC in well.Mechanical water pump I assume, NOT fuel pump?
Is that a CVF Wraptor I see??
Now I'm feeling VERY incompetent.... My CVF Wraptor serpentine belt system, that added AC and power steering, got me to a place where I never thought I'd have room for anything but the low profile flex fan I have. I did buy a new factory fan shroud, (because I sold mine and my 26" radiator and flex fan) and I got a Cold Case aluminum radiator back when the Wraptor was being installed. The big hangup with that plan was that damn 18" two speed electric fan, that smoked its motor 3 times!
Looks great!
Not sure it's fast but it has a full interior and is all steel. Even has battery up front! I have no problems getting in and driving it 45 miles to a neighboring town to their cruise night. Pump gas, quiet mufflers and drives nice.
I used to think 10's in a street car was fast but now I see all kinds of guys with stout turbo'd late model stuff that easily runs 9's.
I've been 10.40 @ 130 and 6.48 @ 105. See no need to go faster than 10's with the safety requirements at that level.
