- 10:15 PM
- Jul 1, 2015
My application may differ because in my case it was for opening the headlight doors. In my case the high and low beam wires were used to trigger relays both for the headlight relays and the solenoids, since both high and low beam activate the solenoids I had to use diodes to prevent backfeeding one to the other. Since they require vacuum to open and to close I used two vacuum solenoids, one wired to the normally open contacts and the other to the normally closed contacts on the relay which are only powered with the key on.
I'm pretty sure I did a thread on it or put it in my build thread, I'll look for it later.
THANK YOU FOR THE INFORMATION.....I can research suppliers for the valves and just about any SPDT relay with 12 VDC coils 12v diodes are available on the internet at reasonable prices.
BOB RENTON
waiting
