- 11:16 PM
- Feb 20, 2012
- New Hampster
You're not done yet?
Will do. I didn't think about that. I have to drain the brand new oil anyhow. Sucks I changed the oil thinking it would help. I bet this oil has 1/4 mile on it lol.Cut the oil filter open....
I moved the lifters from one place to another. It was just a coincidence. In that picture they are in no particular order.If it was the lobe and lifter at the rear of the engine, why is the missing lifter at the front on your piece of wood that has "back of engine" written on it?
Just making sure they haven't been put in the reverse order when you pulled them out.
Awesome.. Good stuff. I will check to make sure there is no binding when I install them. But to note when I pulled everyone of them out of the lifter bores I just hooked under them with my finger and pushed them out and grabbed them with my other hand. So I will say at that point nothing was binding. I was thinking maybe an internal lifter problem. As in maybe stuck inside. I will take the offending lifter apart and show what I find. Now on the same note. I was watching Tonys Garage and he showed that lifters are supposed to rock a tad on a nice piece of flat steel. If they do not then the lifter is flat and not good for rotation. And he also said that its a big issue with modern lifters and the quality control of who makes them.Some old cam break in info in the link.
One tip......
The 1970 Hamtramck Registry - 1973 Chrysler Hustle Stuff (Pg 1) (hamtramck-historical.com)
lol That would be nice wouldn't it.Why don't you just replace the one bad lifter and lobe?
