biomedtechguy
Accelerati Rapidus Maximus
- 12:06 PM
- Mar 28, 2014
- South Louisiana
Are you using the factory metering block on the center carb? One of the biggest advantages to the PROMAX aftermarket center carb metering block is it works much better with hotter than factory cam profiles.I'm wondering if this is due to the size of the cam
I'd ask PROMAX about your issue(s) IF you still have the stock metering block.
PROMAX for 6bbl
