ksurfer2
Motor is a 512 with a cross ram and dual eddy 1407's. Currently, there are breather caps on both valve covers. I want to add a pcv valve to help with some of the oil that is blowing out of the breathers. I purchased a PCV Valve from summit and have a couple of questions. First, Edelbrock recommends hooking the PCV valve to the center port on the front of the carb. With Dual eddy's does it matter that the pcv line is only hooked to to one of the carbs or do I need to plumb it to both (using a T fitting). Second, both carbs have this port plugged with some sort of a plug that has no slot for a screw driver or Allen wrench. How would the plug be removed? Does the carb need to be pulled and the plug removed from underneath???
