Evan Frucht
Any updates? @Evan Frucht
Got the shifter out and swapped it for an unbroken shifter. Cut out new rubber gasket to go between shifter and button housing with some 1/16 thick buna n sheet rubber I had leftover of (can be bought from McMaster Carr.) Wasn't thick enough so I used two stacked together. Remade the rubber isolators for the bolts that hold the shifter unit to that same button housing. Cut one flat end off of some grommets (into a mushroom shape) and that worked perfectly. Made a new button gasket out of some charcoal foam (originally thick felt) which helped firm up the buttons. Should of taken some pictures. After I put it all together I had a little trouble getting the new shifter mechanism adjusted, was getting a little binding at first with the park lever, but was able to figure that out after removing it a second time. Works good!.. (for now !).
Thanks for all the help!
