TOMORROW IS THE DAY……
Red63440
10:12 PM
NY
Tomorrow this
Will be changed to this
With the help of two members of this board, can’t thank them enough…more info to follow.
Hell yeah !! Drop that bad boy in !! One of the bests feelings in the world
We have some great members here,good luck and have some fun.
Did I miss what happened to the old bullet?
1964 361 original 2 barrel to a 1970 383 HP, fresh 516 heads .020 head gaskets giving about 9.4:1 compression, magnum cam with heaver springs, larger SS valves, Edelbrock Performer intake with a 650 Edelbrock AFB, HP exhaust manifolds with 2” exhaust.
Should be quite a change……..
while doing maintenance I found that the guides and seals were bad, head gasket on the right side was leaking, PO had run straight water causing severe corrosion internally, rear seal looks like it’s been leaking for years. I felt that with the chance I was given to pick up a low mileage 383 with fresh heads it made more sense than rebuilding the 361.
1964 361 original 2 barrel to a 1970 383 HP, fresh heads .020 head gaskets, magnum cam with heaver springs, larger SS valves, Edelbrock Performer intake with a 650 Edelbrock AFB, HP exhaust manifolds with 2” exhaust.
Don't forget to let us know who these 'Good sorts' are when the job is done. They deserve some thanks. :thumbsup:
Don and Matt, plan on getting some photos tomorrow.
It’s in, now to put everything back together, huge thanks to Don and Matt, real gentlemen.
D2A7BD31-D1B7-4BB9-8188-51772EEAD50D.jpeg 1DD39D67-766C-41C4-87F8-62AD3E1F0ECD.jpeg 2D9E2C61-57C2-4A85-8350-2D1E564174A5.jpeg FFA20C4B-8899-47BB-919B-5C27A2BE32B3.jpeg CF792973-EF87-4541-BB02-EBCEF7574A21.jpeg 1222D0D2-2916-40D9-B3B5-6CFB21362949.jpeg
These two guys could have stayed home today and relaxed but instead they drove down to help me, this is what makes this site what it is.
it is power though, almost as good.
Not really, the idea of a dual master cylinder is to have a split system where two lines feed your brake system, front on one line and rear on another line. Power brakes or standard makes no difference if you have a brake line rust through and burst you end up with a safety situation.
