383 stroker vs 440 stock rebuild
What engine option would you choose?
  • Total voters
    40
RockyPat
9:18 PM
California
Hello All,
I have a 383 that is in need of a rebuild, and I fear that the crankshaft might not be salvageable. This would most likely mean stroker kit. I can do a 438 or 496 with 440source which would cost me $2300 + everything else to rebuild.
OR, I could buy a 440 core for probably $500+ and hopefully do a stock rebuild with the factory crank. I figure the increased displacement would offset the 383 stroker kit. I am assuming this way would be cheaper, but I am not sure. Maybe I could sell the 383 to recuperate some funds this way.
For a person who is looking to gain the most bang for their buck, what would be the best option?
I am looking for good street power and tendencies, nothing crazy.
Hello All,
Do the 440 great motor.
I have a 400 stroker to a classic 451 build. So I would try the RB stroker project next.
496 would be my preference. I’ve built a few 400’s with the 4.250 stroke cranks and even on pump gas CR’s they are awesome.
I looked at a '67 Belvedere (GTX clone) in half project with the 511/512 stroked 440 build engine. It dynoed 686 HP. Very simular to my 451. The difference? It's lower compression thus hit that number on pump 93. My 451 is 12.3:1 on E-85.
There truly is no replacement for displacement. Especially in the naturally aspirated world.
I'm thinking of the same thing.
Polish the crank: $30
Resize rods: $160
ARP Rod Bolts: $72
Rod + Main Bearings: $200
Wrist Pins: $50
Pistons: $670
Rings: $50
Balancing: $200
Bore/hone cylinders: wash
That's about $1,600 with used crank and rods. So for another $700, you get a new crank, much better rods, and low deck appearance.
Having never done this, coupled with my lack of knowledge and experience, this is where I ended up. So, I'm sure there are other considerations I haven't thought of.
We haven't done a stroker crank in a 383. Mainly because we have 400s and 440s to choose from for a stroker. We've had a 4.25" crank in a 440 for 25+ years. It's pretty tough to beat a 4.25" stroke. Of your listed options a 496 would be my choice over a 440. But 440s can run very good. Certainly the most affordable option.
How often are you going to drive it, how long do you want it to live? In a low deck B block, a 496 will cause a little bit of piston flop in the cylinders and more extreme angles. By nature, most stroked engines do not last as long as stock stroke. My stroked motorcycles always require a rebuild around 1/2 the miles of my stock stroked bikes.
I did a 383/438 build for my drag boat. In my case the crank was no longer usable. How it behaves depends on the heads you use and the cam choice. In a car, I would do the 496 and say "It's just a 383" and smile hehehehe. Either way, if your block is good, it's a fun build.
Our fore fathers have figured this out.
I believe that's a fair assessment. It's true with any performance enhancement. At our local pub I heard a conversation about bashing Ford's modular engine after increasing it's supercharger performance. That it comes apart after only 20 runs? They asked me as the old fart. I said. "What did you think would happen when you increased boost from its designed 8 lbs to 14?" Changing fuel only protects from immediate destruction. You made no upgrade to bottom end. You didn't even add upgraded head studs. You just added a chip to change fuel map to accommodate the increase in boost. Of course it's going to come apart. ALOT faster!"
Often overlooked...a 383 mopar with its 9.98 deck height has a taller deck then a chevy 454 which is only 9.8. Both have the same 4.25" bore=there is more room for a stroker in a 383 mopar.
Most don't hesitate to drop a 4.25" crank to replace the 454s factory 4" crank.
I'd do a stock stroke 400 before doing a stroker 383. Big bore engines are always better in my book.....otherwise do the 440. Easy to make 1hp per cubic inch these days and well.....440 hp ain't too shabby.
So a 690 would make 800 hp.
Heck I will stick with a 440.
Its all bottom line how fast do you want to go.
440 can do more you know that lots have lost the ways.
Keep in mind the rod ratio on a 383/496 is 1.53. A stock 454 Chevy is also 1.53 . Seems those had no problem going a considerable amount of miles in countless GM vehicles. So the rod angle shouldn’t even be a concern. Most after market pistons run similar piston to wall so whether it’s a 440 or a 496 it doesn’t matter. The 496 will have a shorter cd on the piston but in reality it’s not all that bad. The wrist pin is still below the ring pack. Sure a 440 piston will have a longer skirt and be a little less prone to rocking but, what performance big block lasts 100k anyway. The strokers make great street/strip engines. They do need better heads to really see the potential. Being the 383 has a smaller bore careful attention needs to be taken that the intake valves have enough radial clearance to the cylinder walls. And that’s easily resolved with a die grinder.
I have a 400/512 I built in my road runner that’s a street car. It’s been an absolutely awesome engine. I’ve driven and hammered the hell out of it going on 5 years. It’s pretty much zero maint and has 10 sec power. It’s made a few guys believers..
