- 10:48 AM
- Aug 24, 2015
- West Palm Beach, FL
Looking for input on whether to try to repair my 25 yr old Craftsman (DeVilbuss) air compressor. It is a 3.5 hp 25 gal unit. Today it ate the new fan cage I put on it less than a year ago after it ate the original and I have only used it a dozen times or so since. The retaining screw was still tight, but the keyway, which is only on the back face and doesn't go all the way through the thickness, is spun/stripped. I can buy another cage, but there must be something causing the cage to chew up its keyway which then allows it to smack the tank.
The motor and/or compressor has started surging sometimes whereas it used to run a steady rpm. All that has me thinking it might be time to just get a new one unless there's a relatively cheap and easy fix.
