71Beeper
- 10:42 PM
- Nov 28, 2010
- Stoney Creek, Ontario
Or should I say my 1971 "Clone runner".
Hello All, I've been posting on the "what did you do to your car" thread for a bit now.
I'm restoring a 1971 RR tribute car.
I have the majority of my project over on the Road Runner Nest website.
There's 24 pages worth of pics and info.
Here's a link for those of you that are interested.
http://www.roadrunnernest.com/forum/viewtopic.php?f=1&t=4333
Start from the beginning and work your way thru to the end. I usually post new pictures every weekend.
I'll start to do the same thing here.
Here she is in her current configuration.
It's been alot of work up to this point.
So...currently I'm trying to get the Air Grabber setup painted.
I posted on the other thread that I'm not having any of the under hood components
as the Air gap intake I'm running on my small block will interfere with the under hood components.
So I've been having some painting issues concerning the Air Grabber setup.
The initial primer application went on just fine.
The satin black application not so much.
Just a note - I'm rattle can spraying this Air Grabber. So the first product I used is the Mar Hyde satin black.
When I sprayed the underside of the Air Grabber....it went on perfect!
The topside..... not so much.
You may be able to see the streaking.
Anyways, it may be due to the excessive humidity we have had in this area the last little while.
Did I also mention that I'm painting this outside & nowhere near the car....
So, my neighbor, who's a body and paint guy said to try the Rustoleum 2X satin.
So I did.... the problem with that paint is it's too shiny like a semi gloss black, not a satin black. Not to mention every time I sprayed a coat something just had to land on the fresh paint...making me have to go back and re-sand it.
So my third attempt I thought I'd try a flat black paint.
Since the satin black was too shiny I thought maybe the flat would be just like the satin.
Well, I was wrong.
Not to mention the paint reacted and did this...
So, I'm going to wait till the humidity goes away from this area and try it again.
I'm also going to try painting it inside in my other garage attached to the house and I'll sit the Air Grabber insert vertically. Maybe I'll go back to the Mar Hyde satin black and give it another shot.
Well, I was wrong.
ct but then gin, I am not perfect either!
