- 11:49 PM
- Oct 16, 2014
- Salisbury, Vermont
Cudachick1968 finished up my Weiand intake. Spectacular!!
I debated whether to do it or not. Decided, what the hell.I have never seen a K member painted the color of the body but that Is a good look.
If your referring to the bucket horizontal edges catching on the bolts hanging down from above, as they spin open and closed, there are short bolts, 1/2" long, that fasten the frame work that are designed to be short enough to NOT catch the lip as it spins by. Unfortunately, two of the holes are wallered out and those bolts no longer tighten up. So it's now bolts with nuts. I'm trying to keep all of the bolt heads on top the same, as they are supposed to be, but don't seem to have two bolts with the same head and washer as the rest that are long enough to put a nut underneath. That also wont catch on the buckets. I will end up using a longer bolt and slicing off the excess. Maybe even grinding on the end to clearance for the bucket rotation.Maybe an "Elevator" style bolt is what your'e after for the bucket spacing. Looks good!
