So I thought I was getting close to firing this hemi up but after oil priming it I’m not so sure.
Stock block (1970) with a solid roller cam and crane ultra pro lifters and non oiling pushrods.
When priming the lifter that is nearing the highest point of lobe lift is bleeding oil because the top of the oil notches are slightly above the lifter bore. I turned the pump with a battery drill on low so just guessing around 500 rpm and have 50 psi with 10w-40 oil. Should I be concerned with this
because the mains get oil from the passenger side main gallery.
Here’s cam specs
Here’s cam specs
