In the column is a notched plate that you can remove and grind the 2-3 notch so you do not have to pull the lever toward you while shifting.
The detent in the valve body is strong enough to hold each selection of the lever.
once you get the hang of it,a slight tap on the shift lever and "Click" you are in the next gear.
P.S. You can always use a Forward Manual Valve Body and then none of this is necessary.
A&A Transmission and others sell Forward Manual Valve Bodies for Chrysler Torque Flights.
