Whistling Motor, Vacuum leak
Tias63
8:08 PM
BC Mexico
Yes, I'm sure it's a Vacuum leak, but having a hek of a time finding it. I've done the spraying of a water bottle (with water) and nothing as far as changes in the idle. You only seem to hear this whistling when the motor is nice and hot, thus I don't feel comfortable spraying with Brake Cleaner, Carb Cleaner...
Any other tips or ideas?
The only time I've noticed a change is when I disconnect the vacuum advance, and the whistling will stop, but if I rev up the motor it will start again. Weird
I have used a propane torch, unlit of course. Not messy and doesn't ruin paint.
Check the vac advance case body for cracks...also the under hood heat tends to make the stretched ends of vac lines harden and a vac slips around them. Snip off the first inch or so and reattach.
I would try troubleshooting the vacuum advance with a brake bleeding vacuum pump.... see if it holds...maybe the noise is coming from the distributor..
This will sound nuts but I had a replacement pcv valve that would whistle at idle.
It was a plastic napa replacement one.
I swapped in a oem used one and the whistle was gone.
Have you changed the carb base gasket lately? I once tried a single opening gasket under an Edelbtock carb on my 67 GTX and it whistled loudly until I put ac4-hole gasket under it.
383 with a Holley 3310 I believe, Vacuum Secondary
OK. Do all of the above checks.. but holleys can often make a whistle as the air goes by the throttle blades.
Like Khryslerkid said, try giving the fuel mixture screws some love.
Does your car idle OK? I would think that with a vacuum leak you can hear, your car would not idle at all.
All good suggestions :thumbsup:
A former brother in law had a Ferd truck and he said it had a whistle. No one could hear it but him. Well when he changed the PCV valve he said it was gone. Glad it did the trick :)
Idles and runs just fine. I found that if I disconnect the Vacuum advance, the whistling stops until I rev the motor. Then the whistle will return then stop when the motor idles down. The Carb was rebuilt about 2 years ago, but I'm going to clean it up and try a new gasket.
Great suggestions here, have a poly with factory intake with a tad larger carb on it and there’s not a ton of ‘sealing’ room around the base, has to be set square as possible. Check the base for vac leaks as posted and bolts torqued evenly.
