diesel_lv
Well I bit the bullet and ordered one for my 383 stroked to 496. I got tired of pulling the electronic distributor and completely disassembling it, changing springs etc trying to get the curve right. Not posting this to get advice on "how" I should set up a mechanical advance. This is so I can, over time of fine tuning, give everyone a 1st hand evaluation.
It came extremely well packaged, double box, molded foam, plastic wrapped. It looks very well built, full billet aluminum. Instructions are printed and very well laid out, in detail and thorough. Install should be very easy and straightforward if you have factor or Mopar Performance valve covers. I don't. I have 440 Source fabricated aluminum valve covers. This required me to dimple the cover and grind a little off of the distributor cap. But it did clear. Once installed and the app installed on phone, it fired right up. I verified it was at 10° and locked it in. Then via Bluetooth, set the initial timing map. It's going to take some time to get it dialed in, but it performs as advertised. The test will be time and the extreme 125° temps I get here in the summer. It's not cheap, but it can control almost every parameter of timing and make adjustments on the go via Bluetooth.
