Do you have a heated floor? Or maybe an infrared light/heat lamp unit to shine on it?
Here's a saying about luck, "Dumb luck is better than no luck".I bought this carpet from Year One 14 years ago and it's been on the shelf ever since. I haven't even glanced at it and didn't notice until today that Year One sent me the wrong model. I ordered an auto trans carpet for another Charger with a 727 auto. Well, it turns out that I got a 4 speed carpet with the hump which is exactly what I need now! Couldn't believe my eyes.. thank you Year one for your **** up (checked the old receipts and I did order an auto carpet)!
Should I try doublesided tape or sandbags and heat to get the right shape in the corners and flatten it out?
View attachment 1203309 View attachment 1203310 View attachment 1203311
That's a really cool interior!I like the console too, and so much about the car.
I was very fortunate and had a console manufacturer basically make a custom console for me, but the mutual plan was for it to go into production. Long story short, I needed a console for a bench seat Pistol Grip w/out changing the shift lever, after I swapped in aftermarket bucket seats.
Thank's, totally agree. Some really good advice there. You never know what might happen. And one more thing.. don't do it alone, make sure you are two pair of eyes and ears.Words of advice. Don't get in a hurry to light it, don't do it after a long day when you are tired, make sure battery is fully charged, fuel leaks you got handled, roll it outside in case of car-b-que, have extinguisher ready, at least 10 gal of fuel, water/atf [if auto ready].
Congratulations on a good engine start!After sitting for four years, It's ALIVE!!!
Atleast for five seconds until dad screamed at it me to shut it off! He smelled burnt rubber which isn't any good sign.. it turns out that it was the fan hitting my upper radiator hose making a nasty cut into it so that has to be replaced. Not sure why the radiator sits so low and I can't believe I haven't noticed this.
It took me some time to get the right fuel pressure since it wasn't possible to adjust no matter what I did. Only had like 3,5-4psi which isn't enough.
Turns out I had confused the supply and return on the regulator... What an idiot. Luckily I had some AN fittings and connectors to make it work. Anyhow, it'll be replaced when it's time for the holley sniper efi. Adjusted to 7psi after I'd swapped it.
Unfortunately I don't have any footage of the start up but it fired instantly and went straight to a solid idle, no backfiring or stumbling or anything.
I'll make sure to film it next time after replacing the hose. It was loud!!
Well, I guess five seconds of heaven is better than nothing and I know I'll be sleeping well tonight...
Nothing new in this engine. We took it out of a pro street 1968 Charger that my dad owned for some years so we know it's in good shape.Congratulations on a good engine start!
It may be in the earlier posts - is this a fresh engine rebuild with a flat tappet camshaft? If so, then make sure you run the engine at 1800- 2500 RPM for 20-30 minutes to break in the camshaft! (But I'm sure you have this covered, but I figured better safe than sorry!)
Nice work!
