GrabberOrange69
Thought I'd share a little progress from my 470 build.
It's going in my 65 Coronet wagon. I've been saving parts for the better part of a decade, and started moving getting the machine work done and getting it together a little over a year ago.
Block started as a virgin, never rebuilt, mid '70s 400, the one with the reinforced main saddles.
It's got an internally balanced 440 source crank I picked up at a swap meet, 3.915" stroke. It had been run before so my machine shop checked it out and polished it. We used King bearings, Icon forged pistons hung on Eagle rods, ARP bolts on the rods and mains:
We'll be running octane boost/race gas mix, or possibly Snow methanol injection with the 10.8CR.
The last few weeks have centered on prepping the heads and valve train, getting it on the engine. The rockers are a NOS set of Crane adjustables, new Elgin shafts, heads the ubiquitous Steaths.
The rockers had spent a long time on the shelf and had some flash rusting in the shaft bore that I took care of with some Scotch Brite. All assembled with Clevite bearing guard and Comp Cams spray lube
