65-440
- 9:43 AM
- Dec 2, 2009
- virginia beach, va
Ok, so i normally dont ask for much but i'm having trouble with this superbird. 440-6, running very rich, wont hold an idle ... when it does idle it stalls when put in gear. Just went through all 3 carbs, car has been sitting for 2.5yrs, they were nice and gummed up! anyway, timing is at 15 initial, 15" vacuum, outboard mixture screws 1/4 turn out.... outboard carb linkages disconnected, center carb fuel mixture screws all the way in and it still runs. Can see fuel being pulled in from the boosters, only way to stop it is with the throttle blades all the way closed. I have zero 6 pack experience but looking at it like "a carb is a carb" and it is frustrating the hell out of me. On any 4bbl with a function idle circuit, with the mixture screws all the way in it will stall, does a 6 pack not work the same way? I would think it should...What could be causing so much vacuum to be pulled through the venturi with the throttle blade almost completely closed?
