Wietse
Did you just install the shims or also checked pressure output with a gauge, just curious.
In regards to leaks, i found 1 topic from a guy who bought the full kit and burst a seal on the pump housing (reservoir) which is not pressurized so probably was bad luck.
The book states both types of OEM pumps have a max work pressure of 950-1050 psi for all V8 engines, Borgeson claims optimal pressure for their box is 1100-1250 which should work without issues.
Flow rate of 2 - 2.5 gpm can also be met by the stock pumps.
Unless people increase the pump output pressure by changing things on the internal relief valve the stock pump would not be able to blow any seals on the box.
