Max fuel pressure for Carter 3705 carbs?
FMA,
There is some misinformation creeping in here.
[1] Carter/Edel carbs can withstand a LOT more fuel pressure than brand H & clones [ before flooding ] because of the superior leverage ratio of the float system.
[2] Edel carbs that I have seen come with 0.0935" n/seats. From my 1980 Carter catolog under n/seats: 'The two smaller sizes 0.0935 & 0.1015 are std equipment in most AFB, AVS & TQ carbs'. The #3705 came from the factory with 0.1015" n/seats.
[3] The fuel pressure quote in post #15 looks like an Edel quote. I have personally run pressures as high as 10-12 psi at the track as a means of slightly enrichening the mixture; not a hint of flooding. The 1963 426 2 by 4 bbl fuel pressure is listed as 6-8 psi in my Motors Manual.
[4] I would NOT lower the FP below 6psi, that is not the problem. Adding a regulator to a pump system that already has an inbuilt regulator is only going to load the pump more, more likely to cause pressure fluctuations & early pump failure.
[5] Ign timing at idle is mooooooooooooost important with low vac cams & needs to be sorted BEFORE touching the carb. This is a most misunderstood topic, even among experienced engine builders. I saw a YT video recently, cannot remember the name, but the bloke said: Unless you are using 35* minimum at idle, you are not doing it right; he 'gets it'......
Chrysler got it wrong by not using manifold sourced vac adv [ MVA ]. Instead, they used the useless PVA. GM used MVA on high compression, short duration cams. Their cars left showroom floors idling with 24-26* BTDC!!!!!! And you have only 18* with a low vac cam!!!!! You will need a lot more. Test is really simple: engine warmed up, idling, turn dist slowly until you get the highest rpm. Toggle dist to make sure highest rpm has been reached. Now check what the timing is & that is what the engine needs as the initial timing. My GTO idles with 48*. You can use a locked dist, programmable 'box' or adj vac adv dist [ see link below ]
to get the reqd timing. Say your test shows 40*. You can keep the original 18* & use MVA to add the 22*. Most adj VA units allow up to 30* of timing. Screw the Allen Key fully CW [ lowest vac setting ].
Here is quote from D. Vizard, author of 30+ auto books. Note this is about idle timing, but is in a carb book: ' The optimum idle advance is typically 35-40* for a short cammed street engine & [ though not commonly realized] as much as 50* for a street/strip engine ]'.
[6] Once the timing has been sorted [ you can just leave the dist at the reqd timing as a temporary measure ], you can dial in the idle cct. Increasing timing will increase idle rpm [ because the engine is making more HP...& vacuum...with the timing it needs ]. You can now reset the t/blade position. I doubt whether it will be enough close of enough of the t slot, so some extra idle air is probably going to be needed.
[7] Adding idle air. If the carbs still have vel valves in the secondary, I would NOT crack open the secs. AFBs are an ingeniously designed carb & have an ingenious low speed enrichment cct in the sec boosters. These might be activated if the blades are open, causing more fuel flow, the problem you are trying to fix.
[8] The pri blades are alum. Any holes in them can be soldered shut with alum solder & a sol iron [ not the flame type ]. I would drill a 1/16" hole in all 4 pri blades & go from there for bypass air; enlarge in 1/64" increments until you have 0.010-0.040" of T slot showing, less is better. If the mixture screws are many turns out, then you should enlarge the IFR in the pri boosters. Start with a 0.002" increase.
[9] All of the above is tedious work but the reward will be worth it....
MVA, scroll down to post #6.
www.hotrodders.com/forum/vacuum-advance-hooked-up-directly-manifold-bad-47495.html
It's not I have a couple federal mogul Carter publications that are similar.
IMG_20220324_195041116.jpg IMG_20220324_195102832.jpg IMG_20220324_200022839.jpg IMG_20220324_200015689.jpg
I agree more timing advance will likely help.
My chargers 383 idles really well around 25-28 degrees.
Thanks guys, I was afraid to add too much advance at idle. I will bump it up in stages and test. MSD electronic, no vac advance but can adjust max stop bushing and springs. I will do whatever I need to to get this thing to idle without the exhaust killing small animals nearby and making the plugs black as coal. I just love the sound of these things idling, like they are angry LOL.
You can use the vacuum advance connected to the manifold vacuum to "fully advance" the canister giving you initial timing plus what is in the vacuum advance system.
Some engines love it some don't from my playing around.
This is typically done to fire a lean slow burning mixture.
I doubt it will be the magic bullet in your case as your car runs very rich from your posts.
Carter published a chart [ I have a copy ] showing how f/pressure affected float level & how to adjust float level for the FP. The chart goes to 10 psi. Underneath the chart it says: ' Use this chart to decide on the correct float adjustment for your carb.'
While I have your attention, my engine is supposedly 10:1 comp. The dealer said the owner said that 91 octane was enough? I have seen posts where they said for 10:1 and above even premium might not be enough? What would you guys run? Thanks
I have run 91 with 11 to 1, but with a a LOT more cam than you have.
To be honest, with your combo I would run 91 (93 of course if available) with a couple gallons or three, of 100LL avgas. Again, if available to you......
(I can get self-serve avgas at my local tiny airport, about a buck cheaper than california pump premium, last I checked.....)
I don't have a source for av fuel, so would only be able to run octane boosters if that will work
Can you post a copy of that as PDF or photo. Would like to see that.
You would have to ask others here about boosters they like. But be aware that most octane boost boasts are deceptive. For example boost "x" says it will boost octane "five points" . What they mean is point five, from 91 to 91.5.
There are some that have been recommended here that do work.
I don't have vacuum advance, previous owner installed MSD Pro Billet 8546. Not sure why. But car was raced in NY with a 64 max wedge 426 before engine was swapped for a 62 413 oversized to 426 or so. I think for street cars it is better to have the vac advance? I would get an MSD ready to run with the vac advance but then I lose the MSD 6AL because the ready to run is not compatible?
Dragon Slayer,
I am old bastard & not good with computers, do not know how to post. If you [ or anybody else ] would like to see the fuel pressure chart, PM me your email address & I will email it to you.
The MSD RtoR junk does not have an adj vac adv unit, only non-adj. Vac adv HAS to be adjustable to work with your combo. Best bet is to buy one of these from Summit, both are in stock & cheap: SUM-851018 or PRO-6694. Both are mag trigger, will drive your 6AL, & come with adj VA units. I used the Summit one last year; it used the Mallory system for centri wt adjustment, an easy system to work with. WOT timing comes at the end, not the beginning. You do not need a fancy, expensive dist to drive the 6AL.
Because of the poor distribution that intake has, you are likely to have lean cylinders [ detonation ], so I think it will need high-er octane fuel.
Here is that chart which is hard to read. It also applied to Comp Series and 9000 which are Federal. Float is different. So was the calibration. Folks need to remember original Carters had different float system, and calibration as directed by manufacturer. The later carbs became more generic. Mopar went to higher fuel pressure with Carter starting in the 50s. Primarily to prevent fuel boiling in the line when at idle.
Here is an orig Carter float typical of the Chrysler AFB and AVS (though AVS slightly different) versus the smaller float typical of Later Comp Series, 9000s, Edelbrock.
The float is longer and wider by about .1" each direction. So it is all about the buoyancy force it can apply to the needle seat coupled with the leverage ratio. Fuel pressure is converted to a force against the needle face. Float reacts. Smaller needle is smaller area and the fuel pressure times area is force opening needle against the float. Large float displaces more fuel and can apply a larger force for a given displacement to keep needle closed. (Think a loaded small boat versus a larger boat same load).
Also, lots of kits have larger needles/seats than original called for. Kit became generic. Older kits typically have the correct N/S.
The Carb is calibrated for a given fuel level based on correct parts and manufacture fuel pressure. Deviate from that. But don't confuse OEM Carter for Federal and Edelbrock AFBs. Follow their guidance. Float setting are different based on models. Look at those sheets in the kits.
With mechanical pumps pressure is about velocity of fuel flow, and vapor pressure. The pump is positive displacement. Pump the same volume every stroke (less check valve leakage and flutter at higher rpm). If the end of fuel line open, pressure would be barely above static pressure. As you restrict flow via N/S pressure rises until the pump spring force equals and the diaphragm stop moving even if the pump arm is still stroking. So Low speed is usually highest pressure and at high rpm pressure drop because N/S open. But you do want pressure in the fuel line. You want to pump liquid fuel, not partial vapor and liquid. So hot motor and hot day reduces liquid volume pumped. In the end it is a balanced system.
DS,
That chart I sent you is NOT Federal Mogul. The 9000 series carbs came out before FM got involved. I have a Carter 1978 catalog [ pre -FM ] & both 9000 series AFB & TQ carbs are listed in it. I have seen both types of floats used in original AFB/AVS carbs.
Ok but regardless the 9000 use the smaller 188 float. There are some afb that used them too; cad chevy. And one or 2 chrysler. Most chrysler afb and avs used the larger float. Federal documents exist for 9000 and comp series. They dictate lower pressure and different float level.
The chart in post #35. I am going to get my son in law to see if he can enlarge the graph & re-post so that it is more clear. Hard to see, but the text states Carter recommended 7.5-8.5 psi for performance applications & the chart goes up to 10 psi.
Should put paid to the nonsense about 6 psi limits for these carbs. Edel might recommend a specific pressure because changing pressure changes the fuel level, which affects rich or lean.
I agree fuel pressure can be higher, and especially orig carter OEM carbs. I was pointing out that the top of your chart states it is for 9000 series and Competition Series. I do believe CS was Federal. Those carbs used the 188 float. That chart is only good for the specific float used. If your carb had a larger float like OEM, the height adjustment versus pressure for the NS combo would be different. Smaller adjustment needed since the float is larger.
Attached is the Federal AFB guidance for the 9000 series. This is on the web readily. Also a picture of the 188 float. Page 4 states the calibrated fuel pressure and they recommend 5.5, max 6. But this is for 9000 series carbs. So I understand where the confusion comes from, especially when you add the edelbrock documentation and even Holley recommending lower pressures. And it is true you don't need high pressure if you have high volume and the float set right. But high volume doesn't automatically mean flooded carb unless very large seat used and small float.
  • AFB 9000 Series Tuning Guide.pdf
