View attachment 1262434 View attachment 1262435
Received this as a gift from my shop guys. They keep busting my balls to install it. I show it here only because it's been mentioned a few times. Thoughts on the externally mounted fuel sump rather than a new tank with integral pump? All the other parts come with the package. If I do decide to pull the trigger perhaps I'll keep a few spare parts on hand to address the concerns some here have mentioned about being stranded due to component failure?
I believe you can get injectors that handle increased PSI. Would that upgrade along with refining the system tune do what you are looking for or is that too simplistic a solution?It may work just fine for this current set up, but when its time for a freshen up the CR will get increased as well as some better flowing heads.
Don't do it. These sumps have little fuel, get hot sitting in the engine compartment, and actually add complexity. I have heard many with issues that have tried them.Thoughts on the externally mounted fuel sump rather than a new tank with integral pump?
