- 12:03 AM
- Sep 25, 2014
- Dahlonega, North Georgia
Since I can't buy everyone here a drink I just got gold membership to show my support and appreciation for all the advice!
The dodge/plymouth service manual should have it also in chapter 14 fuel. The carter manual says the 3705 float from top of float outer end to air horn gasket is:
15/64" if a solid needle. 13/64" with resilient seat needle. Interesting enough each carb has a different set level. The early 3447/3505; the 3705 and the 3861. Float drop for all is 23/32".
I think you can drive up here to VA and buy me a beer. We have car shows in VA
[1] Regarding the slots in the venturi gaskets. Many Carter carbs have a slot in the venturi itself or in the mounting base of the carb. So whether the gasket has the slot or doesn't, the fuel can transfer. Check your carb carefully to see. Using a slotted gasket with a carb that has slots will work ok.
[2] The 3447 is totally different to the 3705. 3447 has the small air cleaner neck & small primaries. 3705 has the large 5" air horn & larger primaries.
[3] No way would I use Edel carbs. The above carbs have specific calibration for a cross ram, Edel do not.
[4] These carbs are extremely reliable & trouble free. It seems something simple is being missed.
[5] Jetting info etc is in the MP engine book. FL is 7/32" & float drop 3/4".
Bob,
Like most cross ram intakes, whatever brand engine, they require staggered jetting to get some semblance of equal distribution to each cyl. A relic from the past, better options these days, would only use for nostalgia.
Yes that is a problem and will be rich at idle since you won't have the control to limit fuel. Venturi seating correctly can cause issues too so using correct gasket and installed correctly for each side. That still does not explain the leaking fuel into secondary. Far bigger issue.
Well I think I am getting a little closer. Took carbs apart again and noticed on the venturi cluster gaskets that the new ones had small corners where the old ones were rounded, and I think it prevented the venturis from seating against the gasket correctly, so I trimmed them. BUT I noticed that on one carb the mixure screws at 1.5 turns stuck the pointed part quite a ways into the bore, and on the other carb the points were just entering into the bore. Figured the mixture screws were incorrect for one of the carbs, but when I remove and measure them they all measure 1.4 inches. Noticed on one carb the screws gently bottom out pretty quickly, where on the other they screw in a lot and completely compress the spring before stopping. Took a look and it seems that someone overtightened them in the past and it punched the hole where they normally seat out so that they don't stop at that small opening in the bore where I think they are supposed to bottom out?
How badly would this affect the way the car runs at idle? I think even if I tried to adjust by counting the turns in from starting on the good carb and matched that on the bad carb so they they are both pretty close to the same distance into the bore that it would still not be correct since the hole size for the tip has been enlarged? Am I screwed and need a new core?
I took some pics, one carb has one mix screw that when lightly bottomed fits the seat in the bore (circled in red), the other seems slightly broken and allows the screw to enter a little farther into the bore. The other carb is a mess. Both screws lightly bottomed ends up maxing out the springs and as you can see the screws end up bypassing the seat completely as they are both blown out. I would think these would just allow fuel to flow unregulated?
Thanks as always
Forrest
View attachment 1266244 View attachment 1266245
Bob,
I think the difference between a CR intake & modern tunnel ram or single 4bbl intake is that the modern intakes have the carbmore centralised in relation to the runners & this gives better distribution.
The fact that an intake needs staggered jetting is an indication of uneven airflow & the greater the difference in jet sizing, the greater the airflow disparity.
Idle mixture screw holes. They could have been enlarged in a misguided attempt to increase idle fuel delivery. They may work OK as is, as long as they bottom out for the starting point. Screws may not be out as many turns, but ok as long as they regulate the idle mixture.
