Hey, KD.Now that I am faced with pulling the engine, I want to do a remove and reinstall from underneath. To do this, I needed to make some sort of cart to support everything. I started a thread on that too:
https://www.forbbodiesonly.com/mopa...nstall-from-underneath.246546/#post-912250641
There were some great ideas posted there. I took some cues and started making my own. First up, I took a spare K member and a bare 440 block.
View attachment 1293000View attachment 1293002
Then I took a couple of steel dollies and welded some 2 x 3 channel....
I noticed that the bottom of the K member had holes in it, not sure of their purpose originally. I decided to use them as guides to hold the engine to the stand. I welded 2 old 1/2" bolts to the "pads" so the K member cannot slide off.
It is some bonehead engineering but I think that it will work.
More updates tomorrow.
It runs right up to just shy of 200 and never goes past that.And your engine coolant operates at what temp even on those hot days ?
Your bearing clearances say 10W30
Your oil temp would bee next if concerned
If your oil pressure is fine and coolant temp is fine on those very hot days then
Why did you switch oils and add an additive when things where good with the Valvoline VR1 ?
The weight of good aftermarket rods are more consistent than the old school forgings so they don't need big balance pads for balancing. You can still grind on the top of the small end and the sides of the big end if needed. Lighter pistons shouldn't be a problem. You still need to weight everything to compute the new bobweight for balancing.I asked the machinist to deck the block. He stated before that Mopar blocks are often hard as diamonds and wear him out! I'm aiming for anything between .005 to zero deck. Zero deck with the Fel Pro .039 gasket puts me at 9.8 to 1. .005 deck clearance is 9.7 to 1.
Here is a question that I'm unsure of.....
How is balance achieved in an engine if the rods don't have those stock type pads on the cap to grind on?
I have "Manley" H-beam rods with no pads on them. What if these pistons are lighter than the Ross pistons I've been using?
