biomedtechguy
Accelerati Rapidus Maximus
- 5:33 AM
- Mar 28, 2014
- South Louisiana
No sir.So to boil it down , you're looking for a slick that'll put a 4000 pounder into the nines and and be good in the rain?
I already posted that I'm consigned to having a pair of rear tires and wheels strictly for track duty...
BUT
I would like some really fat rear tires and wheels that match the front wheels in appearance (once I get the AMD tubs installed and any other required mods. I will likely have to have my rear leaf springs-Calvert split mono-and rear sliders relocated inboard, whatever)
To be clear, the requirements for the "street" rear tires are they MUST allow me to drive on the highway and elsewhere SAFELY should the roads be wet, or if I get caught in the rain.
An example of what DOES NOT work for me are Nitto 555R drag radials. I had a pair, 295/16 ?, on my 89 Conquest TSi. They were broken in but had lots and lots of tread and tread void, and they suddenly broke loose after about 10 minutes of 60 MPH careful driving on a blacktop Interstate highway in a medium rain. Fortunately I went into the grassy median between the two highways, no concrete or steel culvert(s), deadly drop offs, trees, or cars or other bad things. After I pulled the seat cover out of my butt cheeks with needle-nose pliers, I was able to get back on the highway and only had a lot of grass all over and in the outside parts of the Conquest. The point is, I was blessed, and could have died, destroyed the car, hit others, all kinds of bad stuff, and they should NOT have lost traction in my opinion, but they did, and Nitto 555R drag radials are forever on my "do not use" list.
IF the "street" rear tires are close to track tire/slick performance, say within 2-3 tenths of a second in the quarter mile, I may have them do double duty. Again, the requirement for the "street" rear tires is they MUST have safe traction under careful driving input from me if the roads are wet or I get caught in anything but the heaviest of rain events on the highway and elsewhere.
BUT I would also like them to provide enough traction to be able to get my Roadrunner moving out on dry roads, even if I have to put a bit of heat in them with my line lock and throttle it less aggressively. It would likely be very rare to have a serious "competition" on the street, but if I do, or I get into one of those "situations" and the dedicated track tires are not an appropriate or available option, it would be REALLY NICE to have a pair of street tires that let me put some power down, but not destroy the Roadrunner if I hit a rain storm or a couple of puddles, while I am driving carefully in order to make my destination or during a longer distance "cruising event".
