- 10:23 PM
- Oct 16, 2014
- Salisbury, Vermont
Ordered 6AN to 1/4NPT coupler, 6AN 90* swivel to 6AN hose end, 6AN braided steel hose , 3/8" NPT to 6AN coupler, and a single 6AN hose end.
Tires and brake shoes came so far today....I guessed right, the fronts and backs are almost the same height. The fronts are about 1/2" shorter.
11 1/2" wide. The local Tire Barn says they can mount and balance them for $30 per rim without scratching them. They happen to be located next door to the local Ford dealer who has a racing operation going and they do all of his stuff.Meaty!!
Because there is an oval chrome piece that trims out the clear area from the red on 66T Bird. I'm not using the trim because it will look like a Ford.Why are there holes?
Perfect! Thank you!This will make short work of those holes in the lens. 1803 - SMALL CLEAR PLASTEX KIT
